Block removal on a 51 b
BRIAN
08-23-2001 19:13:16
I HAVE A 1951 JD B THAT I AM TRYING TO REMOVE THE BLOCK ON BUT I CANT GET MY HAND AND ARM IN THE CRANK CASE TO UNDO THE OIL LINE ON THE BACK OF THE BLOCK. I HAD NO PROBLEM DOING THIS WITH MY A BUT THIS B IS A PAIN IN THE BUTT. ANY HELP WOULD BE GREATLY APPRECIATED THANKS IN ADVANCE BRIAN
WTW
08-24-2001 06:41:53
 Re: block removal on a 51 b in reply to BRIAN, 08-23-2001 19:13:16
Brian, 1946 was the last year that you had to go inside the crankase and unhook the rocker arm oil supply line. After that the line was hooked to the case were a through hole was drilled and the block matched up to the hole sealed by the mounting gasket. So go ahead and remove the block, The oil line is not attached to it. Good Luck Dave W
Chuck
08-24-2001 04:32:32
I didn't remember that there was an oil line to the block. May be wrong, maybe you should check you parts manual.
