JD 2010 unburned fuel
Chilean Farmer
11-26-2003 06:09:24
Hi, I'm writting from Chile. I have a '65 JD 2010 diesel and after an overhaul my problems started. In idle (ralenti) and/or no load apply the smoke (unburned fuel) is 10 times more than before the overhaul.
I'm sure that the fuel pump is in the right timing position because it is exactly in the D/C mark when the pump injects fuel in the cyl1 (TDC). I think that the problem is in the timing advance. I read in this forum that the pump should be advanced in 6 degrees adjusting an ALLEN screw but I can't find this screw !...could anybody help me ? thanks very much
Kent of SW MO
11-26-2003 07:44:15
 Re: JD 2010 unburned fuel in reply to Chilean Farmer, 11-26-2003 06:09:24
I thought the timing on most injector pumps was between 15 and 20 degrees before top dead center.
jdemaris
11-26-2003 06:19:02
If the Roosamaster pump has an advance adjustment it will be a small stud with a lock-nut on it. Some pumps don't have the adjuster, only shims. Not quite sure what good it will do you unless you have a plastic timing-window to actually check the timing advance. Procedure to check adance is, #1 remove the little steel door that is held on by two screws, #2 install plastic degreed timing window, #3 run machine at several speeds and check degrees of advance. Without the window you are just quessing.
Chilean Farmer
11-26-2003 11:58:50
 Re: Re: JD 2010 unburned fuel in reply to jdemaris, 11-26-2003 06:19:02
After several hours looking and thinking I suppose that the "plastic degreed timing window" is a tool, external tool and not incorporated in the pump body ?
Chilean Farmer
11-26-2003 07:57:40
OK I'm going to check if the plastic window exists
DON
11-26-2003 07:08:01
The advance on that pump is a "load advance" not "speed advance" . It is adjusted with the engine under full load and the timeing window installed. as I remember it is 6 degrees advance, however you can adjust the trimmer screw with the engine at wide open throttle, adjust until the engine smoothes out and smoke disapears, that will be close. Thats assumeing the pump has the advance on it. Don
jdemaris
11-26-2003 17:48:20
 Re: Re: Re: JD 2010 unburned fuel in reply to DON, 11-26-2003 07:08:01
I've seen some with no external adjustment, some with load-sensitive advances, and some with R.P.M. sensitive advances that work off of fuel pressure. Some also have a trimmer adjustment for metering valve travel. I didn't want to confuse the issue too much, but guess I should have made it clear that the plastic degreed window is a service tool. If the timing is actually causing the problem, it can be crudely remedied by upping the static timing.
Chilean Farmer
11-27-2003 06:13:50
 Re: Re: Re: Re: JD 2010 unburned fuel in reply to jdemaris, 11-26-2003 17:48:20
Some possibility exists that the problem can be due to the valves, valve seats and/or valve springs ??
Chilean Farmer
11-26-2003 08:00:23
Don, where is the trimmer screw ? and like that it is looked ?
ray
11-26-2003 17:40:20
 Re: Re: Re: Re: JD 2010 unburned fuel in reply to Chilean Farmer, 11-26-2003 08:00:23
I got one 180 out of time by putting pump in wrong there are dots on end of pump that must corespond with dot in hole mine ran but slobbered with no power
Chilean Farmer
11-27-2003 06:08:42
 Re: Re: Re: Re: Re: JD 2010 unburned fuel in reply to ray, 11-26-2003 17:40:20
I have a lot of power and I'm sure that my problem is not the 180 degrees. I believe that my problem is the advance of the pump. In fact never I have seen a mechanic adjusting the pump with the plastic window tool
