420 Carb
ole
08-22-2001 15:31:50
I discovered that the Carb on my 1956 420 Crawler is not the right one. In fact it is the same "Marvel- Schebler" used on my Ford 2N. Can any one please tell me which one is the right one.
TSX -641 -678 -688 -689
This is not a dual fuel. Believe it or not, the crawler did run on that carb but I just rebuilt it and don't want to modify the mount to reinstall it.
Leon R
08-22-2001 19:13:05
 Re: 420 Carb in reply to ole, 08-22-2001 15:31:50
The carb that came off the 420C that I have is a tsx-641 It also has 2 56 stamped below that.
Ole
08-22-2001 21:48:11
 Re: Re: 420 Carb in reply to Leon R, 08-22-2001 19:13:05
Thank you for your help. This foreum is the best.
Clooney
08-22-2001 16:12:11
Ole, it could either be the 641 or 678/689. The 689 is just a replacment for the 678, & the 688 is for a later tractor. I just can't tell you if the 641 or 678/689 will both work the same.
