Early styled B {40's} drains and fluids
Mike Langran
08-22-2001 15:15:22
I got to draining this B and it has 3 drain plugs.I know one is the oil and one is gears; is the other one for the lift (no 3 point Hitch. I need a manual.Did those B'S use gear oil in the lift? Thanks, MIke
Jerry S
08-25-2001 11:41:28
 Re: Early styled B {40's} drains and fluids in reply to Mike Langran, 08-22-2001 15:15:22
I am not an expert but I think you had the right idea of needing a book. My book says the power lift should take thinner oil around 20 weight. There are two plugs that will drain the gear oil. One is a pipe plug and the other is that one with a recessed square hole in the middle which drains the rear axle but they share the same gear lube. If you put 90 weight oil in the lift you could be up for some problems.
Prune Picker
08-22-2001 15:50:27
I have 80-90W gear oil in my '44 lift, same as what's in the gearbox. Seems to work just fine. I've heard others say to use 140W in the transmission but a quality 90W does the job and I wouldn't put 140 in the lift.
