Clear coating parts question
Don
08-22-2001 10:58:24
There are a few parts such as the carb. and etc that I want to leave with a clear coated metal finish. What would be good to use on this? Polyurathane? If the brass parts are coated in this will it keep them from turning? Thanks
Gman
08-23-2001 19:01:08
 Re: Clear coating parts question in reply to Don, 08-22-2001 10:58:24
Don the way I do my axles and belt pulley's,I go done to parts store and get me a can of spray Lacquer and coat them. Now this keeps them from rusting and they look nice,unless you are looking for a deep finish that they put on these clocks that you hang on the wall,I think that is some sort of clear epoxy. Gman
Cliff Neubauer
08-22-2001 16:52:24
Try asking at the site below, there are many expert painters there.
Don
08-22-2001 18:42:01
 Re: Re: Clear coating parts question in reply to Cliff Neubauer, 08-22-2001 16:52:24
Thanks Cliff! I'll do some reading over there before I paint.
Cliff Neubauer
08-23-2001 15:16:08
 Re: Re: Re: Clear coating parts question in reply to Don, 08-22-2001 18:42:01
Any time spent at that site is time well spent if you are going to do any painting. I have also bought a paint gun and a Hobbyair supplied air system from it and got an exellent deal and service.
Clooney
08-22-2001 15:30:26
Don, I usually use Dupont Centari Emron. It is a 2 part that is tough as nails won't turn yellow like some urethanes & doesn't chip easily. The down side is it's cost & it would kill the Devil if a fresh air breathing system isn't used & the gun MUST be cleaned as soon as done or it will never work again. Ask your local paint store what they recommend for a more reasonable substitute.
Don
08-22-2001 15:50:12
 Re: Re: Clear coating parts question in reply to Clooney, 08-22-2001 15:30:26
Clooney, Thanks for the info. I don't have a moon suit to wear while spraying that stuff and no more than I have to do I would like something a little "handier". I'll ask the local "experts" as you suggested.
