How to Use Hardner
JDDan
10-14-2003 20:50:48
I have made up my mind to paint my most recent restoration (1950 Model A) myself instead of sending it out. I have already purchased the equipment (a gravity feed HVLP gun)and have become familar with it painting my model KBA wheel disc.
My question is this: Is it best to use the hardner in all coats or only in the final spraying? My hood and grill are already done because of the metal work required. The main chassis,wheels, fenders, and battery box is all that remains. I have primed with JD primer and will be using JD Classic Green with JD hardner if I can find it. Whats your recomendation???
Thanks In advance!!!
rick
10-23-2003 17:59:22
 Re: How to Use Hardner in reply to JDDan, 10-14-2003 20:50:48
there is a intergrated reducer and harderner that will work great if your interested i sell it email me i tell you more
Kenny
10-15-2003 11:17:03
I have done several and for best results put the hardner in every coat of paint but do not use in the primer. I have tried a few different types of hardner and I prefer the PPG brand or one that is available here in middle Tennessee that is called Wet - Look hardner. With either one I use about 2 ounces of hardner in each quart of paint and I mix my paint at 50 % JD classic green and 50% thinner and the 2 oz. of hardner and apply 6 or 7 coats and always get a nice glossy finish and I have 1 that I did 6 years ago and it still looks very good. Another important thing to remember is to not try to get all the paint on in 1 coat, you'll get a better finish by using more lighter coats, than with 1 or 2 heavy coats. Hope this helps and the wet - look hardner is $ 15.00 / pint and the PPG is $ 28.00 / pint in my area.
Ed
10-15-2003 09:15:23
JD doesn't make/sell a hardener under the Deere name. However, my dealer and others now DO sell hardener and some people even prefer it over NAPA brand. I also understand that it's cheaper too. ($31 and some change/pint). It's a Valspar product in a black can.
Clooney
10-15-2003 08:53:53
JDDan, on the use of hardener? You need to put it is each coat [not the primer though]. The absolute worst thing you can do is put hardener in the last coat only. What happens is if the hardener is only used in the last coat it chemically links & hardens faster & more through then the underlying coats. Problem is, that traps the solvents from the earlier coats under the top coat & eventually that solvent can pop through & give solvent pops & can even cause the paint to lift.
~Keep in mind when using paint hardener that most paint hardeners contain Isocyanates & those iso�s can be VERY BAD for you immediate & future health. Do some research & READ the warnings on the product. Personally I WOULD NEVER even think of using any product that contains Isocyanates without a full mask with a continuous fresh air supply. Even painting without a hat, gloves & protective clothing when using iso's can be hazardous...
Joe
10-15-2003 11:00:41
 Re: Re: How to Use Hardner in reply to Clooney , 10-15-2003 08:53:53
Clooney has a great point on those paints.
Not only are isoycyante bad for your repsiratory system it is bad for your skin when used in spray application. It is one of the very few chemicals that a person can become sensitized to which can totally screw your body up and it doesn;t take much!
When using two component paint with isocyanates use a supplied air repispirator and tyvek coveralls. The negative pressue $20.00 cartridge respirators don't work becuase the Permissble Exposure levels are lower the the confidence levels of the cartridge, and how do you know the unit even fits properly!!!
Remember when using a supplied air respirator use good air, no piston driven compressorS, rotory oiless units only! Electic or gas driven piston units can create Carbon Monoxide and then it gets in your air line and you are dead!
Henry J
10-15-2003 06:03:03
JD
Take the precautions on the hazards that are produced by the hardened paint when you spray it. You are probably already tuned into that but it never hurts to check, there is no second chance. NAPA has a disposable mask/respirator (16 to 18 bucks) that is supposed to have ample filtering for one paint job. Obviously the way to go is full suit, external air etc - However.
JDBob
10-15-2003 05:15:17
JDDan,
Good advice from Mark.
JD doesn't make hardner, I'd suggest going to your local NAPA and getting some NAPA 8010 Synthol Hardner.
I've used this on several tractors with JD Classic Green paint, you won't go wrong.
JDBob
RS
10-15-2003 19:07:27
 Re: Re: How to Use Hardner in reply to JDBob, 10-15-2003 05:15:17
JD dosen't make a hardener, they do not make their own paint, but they do have a hardener for their paint called Valspar. It has just been available recently. I understand later on it will have a JD label. I have used 4 pints and it does a excellent job at about $30 a pint, better than the $55 a pint NAPA hardener.
Mark
10-15-2003 04:50:02
You won't find JD hardener. Go to your local parts house that has paint materials and get a hardener for synthetic paints. Follow the directions on the can, and use in all coats.
