B carburetor (gas only)
Wilson
08-20-2001 17:49:03
When the bowl retaining nut is removed there is a spring in the bowl, I can't see what this spring is supposed to do. Should there be another part that should come out with the spring. I looked up in the bore and all there seems to be is a 1/8" hole. Is something missing?
Thanks
Clooney
08-20-2001 18:04:41
 Re: B carburetor (gas only) in reply to Wilson, 08-20-2001 17:49:03
Wilson, that spring holds the "nozzle" (the brass thing with the 1/8" hole in it that you saw) up & in the bore. It goes between the nozzle & the inside of the big nut. Those nozzles tend to stick in the bore after they are in the carb for a while & you need to thread a screw into the bottom of it & put a pair of vice grips on the screw & hit the vice grips in a downward direction with a hammer to remove it, unless you happen to have a little slide hammer handy.
