Gas tank repair
outside
John in OH
08-20-2001 17:30:10
I have one or more small pinhole leaks in a 1937 B gas tank. They appear to be directly over the location of the rear tank support pad. Does anyone have any experience making a tank repair from the outside - ie., without using an internal tank sealer? Will JB Weld hold against gasoline?? Is there some product actually manufactured specifically for external tank repair?? Any other ideas?? Thanks!
Bill Pries
08-21-2001 08:18:19
 Re: Gas tank repair - outside in reply to John in OH, 08-20-2001 17:30:10
JB Weld does hold up to gas. I've seen a couple automotive tanks patched with it and did one myself in my truck. I've even used JB Weld inside carburetors. No problems. I use regular JB Weld, not the quick weld, though I don't know that it wouldn't work as well. Good luck.
Mike
08-21-2001 07:37:21
Have you tried brazing the tank? I've heard it working on a Chevy truck gas tank.
Chuck
08-21-2001 07:04:48
I had a gas tank repaired on a 620. The radiator shop used a coating that made a lining inside and it worked perfect. Cost about $100. I don't know if you can go much with pin holes.
Clooney
08-20-2001 17:42:06
John, the best repair is to pull the tank, purge it, fill it with water & solder the pin holes. About anything else tried from the outside will not hold up long & you don't want a change in temperature that expands the tank a little to cause a gasoline leak & burn your shop or barn down. If you don't want to do it yourself most radiator shops will do it for a reasonable amount. It only takes a few minutes to pull the tank on an unstyled J.D. tractor.
Richard
08-20-2001 17:35:48
Don't fill it all the way to the hole. Just kidding.Gas tanks can be welded. And I have seen holes fixed with fillers, although they aren't as successful.
