Pto on 530
alan
08-18-2001 20:58:51
I have a 530 that I use a mounted double seven sickle mower on. When I was using it today, it developed a sort of gear grinding noise under the floor. Sort of like gears aren't meshing right. The PTO is currently still working. Didn't notice anything unusual. When I disengage the pto with the pedal, the noise is still there. If I take the pto completely out of gear with the lever, the noise quits and the tractor seems normal. Does it sound like a bearing? How involved is it to take the thing apart and look at it? How expensive to have someone do it? Also, ever since I can remember, several years, the pto clutch would never stay ahead without keeping your foot on it, as soon as you take it off, the pto quits, what do I need to do with that? Thanks.
