Aint good....gotta weak 2510.......
john2510-3020
08-14-2001 19:11:12
hello all i ahve a 2510 gas that seems to be getting weak in the clutch area. when you go to let the clutch out it wont disengage until about 1/4" from the end. i was woumdering if i was in need of a clutch repair or could i adjust it? also it is getting pretty bad on oil consumption...when mowing i have to add a quart a day then i can go week with out it ever useing a drop...would i be better off to just sell my beloved toy or spend teh money to make her well again? seems shes weakening by the day...i really hate to see my old farm hand go but i guess theres a day when we just have to let go....but if you could help give me some insight as to waht i can do to cure her or what? thank you!
john2510-3020
p.s also what is the oil pressure supposed to be on her? it runs around 27lbs normally but since the oil consumption maybe that would change it? again thanks
john2510-3020
08-15-2001 18:00:37
 Re: aint good....gotta weak 2510....... in reply to john2510-3020, 08-14-2001 19:11:12
thanks again guys!! big john what year is your 3020? i have a 3020 but its gas also. do you or rod know around how muchit would cost to have a complete rebuiled and clutch job?i do love this girl she has seem to been able to do anything and everthing i could ask. the tractor has no-telling how many hours on it. back to the 3020 i was ahveing some problems with it this past year never used oil or anything but got to where it just would not run had the head done along with a valve job still didnt fix it come to find out it was a .10 cent screw in the carb. still hasnt helped it on gas though....but she runs like a new one must say it looks new too!!! again thanks for the help for my 2510 john2510-3020
BIG JOHN
08-15-2001 04:05:00
Keep It! You could buy something else that could have problems. you know what you got. Gas engines are relativly easy to rebuild. clutchs do go out after time. bite the bullet and fix the 2510. sounds like you really love her. once done youl know what you have and should last many,many years.
Big John Fredonia WI 3020D.....
rod
08-15-2001 03:29:24
I believe it is better to fix a machine you know than take on one that may have serious problems you don't know about. Sounds like you need a ring and head job you should do a compression test first. A clutch is not to bad and just might need adjusting. I have an I and T shop manual for the 2510 email me if you would like to purchase it. regards
rod
