70 Hubs
Leroy Dupree
08-14-2001 18:51:11
Did they every make hubs for a 70 John Deere to go from cast centers to 9 hole pressed wheels?
G Taylor
08-15-2001 16:17:09
 Re: 70 Hubs in reply to Leroy Dupree, 08-14-2001 18:51:11
www.unverferth.com has everything that's required & then some.
Leroy Dupree
08-15-2001 17:53:08
 Re: Re: 70 Hubs in reply to G Taylor , 08-15-2001 16:17:09
Thanks for the info.
poorerbut
08-15-2001 05:53:36
M & W Gear use to make a 'genaric' 9 bolt hub for
duals that had a key-stock and diameter that would
fit a '70 axel. They weren't very popular and
tended to mess-up the pinion grooves on the axel.
I saw a set used years ago and they only got used
one time before the guy bought snap-on duals. I
did see a set of 'custom-hubs' at a show last
month but the guy welded them to the axel!
Doug in Il.
08-15-2001 06:39:16
 Re: Re: 70 Hubs in reply to poorerbut, 08-15-2001 05:53:36
I've got a set of these I took off of a JD 4030 last year. They have been on the tractor since 1975. There is no axle damage on my 4030. I've got these hubs and a set of wheels with 16.9 x 34 tires. If anyone's interested in them, email me. The 4030 has the same axle diameter as my JD 70.
Leroy Dupree
08-15-2001 17:56:49
 Re: Re: Re: 70 Hubs in reply to Doug in Il., 08-15-2001 06:39:16
I sure am interested in a sett of hubs for 9 hole centers E-mail me with price.
Wendell..MN
08-14-2001 19:35:18
yes, I have a set that are used for hub duals on my 730, they come off a 70 and are factory John Deere
Leroy Dupree
08-14-2001 21:47:28
 Re: Re: 70 Hubs in reply to Wendell..MN, 08-14-2001 19:35:18
Wendell, I looked in the 70 parts catalog and they don't show a 9 hole center pressed wheel for a 70. Do you have a part number? Thanks for the E-mail reply. Leroy
Jack
08-15-2001 14:17:25
 Re: Re: Re: 70 Hubs in reply to Leroy Dupree, 08-14-2001 21:47:28
Go to your local dealer or find a farmer that can spare a set.They are 3 1/8 inch diameter and ones off a 4020 adapted for duals will work.I bought a set of M&W hubs for mine and fit perfectly.They go used for around 150.00 to 250.00 depending on who you get em from.Good luck,Jack(TN).
jdeere70
08-15-2001 17:34:17
 Re: Re: Re: Re: 70 Hubs in reply to Jack, 08-15-2001 14:17:25
They are the same as 3010-4010-3020 not 4020. A 4020 has 3 3/8 inch axles. Scott
Leroy Dupree
08-15-2001 18:02:30
 Re: Re: Re: Re: Re: 70 Hubs in reply to jdeere70, 08-15-2001 17:34:17
THANKS SCOTT. LEROY
