JD 620 Standard Fan Removal
Dick Roundy
08-12-2001 19:50:31
I have a 1958 JD 620 standard gas. Any suggestions on compressing the fan clutch spring to remove keeper and then fan without removing radiator. Thanks Dick
Clooney
08-13-2001 02:56:22
 Re: JD 620 Standard Fan Removal in reply to Dick Roundy, 08-12-2001 19:50:31
Dick, either pull the radiator or governor. I don't care what the manual says I have never had one that will come out without at least moving the rad. forward & if that has to happen the pipe is disconnected from the rad anyway. Even if you could squeeze the fan out you take a big chance in poking a hole in the radiator trying to compress the fan spring & it isn't worth it.
Donwisc
08-12-2001 21:07:39
I took it as a chalenge to do what you are suggesting and by the time I made up a compressing rig ,I found I still had to move the radiator to get the the fan and ps unit out. Its a lousy piece of enginering but if I had to do it over again I would move the rad and be done with it. Maybe someone else has had a better idea or success. Good luck Don
