Instead of lead washers...
Dirk
08-11-2001 21:44:27
could I put a couple wraps of soldering lead on the headbolt studs instead ? Thanks.
Mike Aylward
08-12-2001 18:24:06
 Re: Instead of lead washers... in reply to Dirk, 08-11-2001 21:44:27
Dirk, I have been known to get caught needing a tractor on the weekend after the dealers are all closed, and I have sometimes taken the remains of a lead washer and rolled it into an overlapping ring and used it again. Works fine. Sometimes there isn't enough left to do this, and yes, it is better to get a new one, but if you are caught and don't have a choice this will work because I have had to do it many times. If there is corn to plant and the tractor is down and you need it, sometimes you do what you have to do. But if given a choice, get a new washer, plus a few spares in case this happens again. Hope this helps. Mike
Clooney
08-12-2001 05:26:59
Dirk, you could but it probably wouldn't work very good. It would have to be pure lead (not 60/40 or some other alloy) have no acid or rosin core & be flattened & wide enough to squeeze under the nut & not in the cavity between the stud & head hole.
Charles
08-11-2001 23:18:46
Dirk, It may work, but for a dollar you can get the real thing.
Charles
Dirk
08-12-2001 08:59:36
 Re: Re: Instead of lead washers... in reply to Charles, 08-11-2001 23:18:46
Thankyou Gentlemen,I will get some lead washers before I proceed.
