A govner-Clooney
Bob
08-11-2001 13:29:43
I got the left cover off, and 10 round bearings fell out. Without a breakdown I am not sure where to go from here. Hopefully there are only 10 bearings in there and none fell down inside. I did not see bearings in old4u will check Roberts carb next. wish the new shop was ready, it goes up next week, the A is outside under a tarp. Advice greatly appreciated. Bob
Clooney
08-11-2001 14:52:53
 Re: A govner-Clooney in reply to Bob, 08-11-2001 13:29:43
Bob, did the balls that fell out come from the L/H governor shaft bearing? If so those aren't the balls that you are looking for, the thrust bearing is in farther & between 2 washers up next to the little fork in there. I believe that outer bearing is still available from Deere. I'm in the shop right now so when I get to the house later I will try to send or post a governor parts break down. Don't destroy the gasket(s) that are between that cover & governor as they are really shims.
