4020 bore
dave
08-11-2001 13:22:33
what is the largest bore you can get to work with 4020 sleeves. I have a pair of 4.625 pistons that fit the rods I am trying to fgure out the sleeve type to use
david val
08-11-2001 20:44:01
 Re: 4020 bore in reply to dave, 08-11-2001 13:22:33
the 4020 inside bore is 4.25". the sleeves are not resizeable. if you machine them anyway, you get thin wall on the sleeve that might not hold the pressure inside.
anyway 4.625 is probably more then the sleeve's outside diameter.
david
