JD 60 Rockshaft Operation
Tim Maurer
08-11-2001 07:16:53
I just put an aftermarket 3pt on my JD 60 rockshaft. The 3pt raises ok but immediately drifts down. What is likely the problem?
Clooney
08-12-2001 06:46:49
 Re: JD 60 Rockshaft Operation in reply to Tim Maurer, 08-11-2001 07:16:53
Tim, the most likely cause is a worn or torn seal on the power-trol piston, followed by a stuck valve in the power-trol. My money is on a bad piston seal though. Keep an eye on the level of the power-trol oil & if it goes down & the rear axle fluid increases you could have a blown gasket between the power-trol cylinder & rear housing. I have seen a few 60's leak there lately.
2-cylinderexpert
08-11-2001 20:06:20
notv enough hydro oil to support
