3020D- remote svc
BIG JOHN
08-11-2001 06:00:13
remote has small cracks in where the locking balls are and drips. can this unit be rebuilt. or does the whole casting where they are located need to be replaced.
JOHN..... WI
Illinois Red
08-11-2001 10:33:50
 Re: 3020D- remote svc in reply to BIG JOHN, 08-11-2001 06:00:13
Unless the casting is broken then you can rebuild it. You will need 2 barrels, 12 little balls, 2 big balls, 2 springs, 2 plungers, 1 seal kit, 2 flip levers, 2 springs for the flip levers, 2 or more e-clips to hold in the flip levers (these are easy to drop and lose), and maybe the ball retainers over the balls that hold your hose tips on. To take it apart knock out the top freeze plugs, remove the snap rings in front of the barrels, remove the e-clips and springs, remove the flip levers, slide out the barrels, clean out the casting thoroughly, remove the o'rings and back up rings. To assemble reverse procedure.
THANKS RED-_BIG JOHN
08-12-2001 05:38:42
 Re: Re: 3020D- remote svc in reply to Illinois Red, 08-11-2001 10:33:50
Thanks Illinois red for the info!
