JD Model 655N SN420274
don
08-10-2001 21:06:19
Would like to learn more about this model. Will it take cat 1 tools? Can you put a front blade on it (there doesn't seem to be any hydraulics up front)? Is it supposed to have seat belts (it has a roll bar but no seat belts)? Parts problems? Weight? HP? PTO speed? Idiosyncracies? It had a relatively short production run which is curious since it seems to be about the right tractor for a smaller property.
JD70Jim
08-11-2001 07:11:13
 Re: JD Model 655N SN420274 in reply to don, 08-10-2001 21:06:19
According to Hotline, it was produced from 1986-89 so you're right about the short run. It Has a Yanmar 3cyl diesel of 40.1cid and is supposedly (according to Hotline) 10.6pto hp. It is HYDRO, weighed about 1415# and yours is a 1987. The 650 was 14.5 hp and the 670 was 16 pto hp, so the hp for this tractor is probably about the same.
