JD 70 Rocker shaft enable?
Ken M
08-09-2001 17:19:48
I want to try to put 3 pt hitch on my JD70 and was trying to see if the rocker arm works. The manual says to put in the oil line coupling plugs, but I don't have them. I am going to try to make some (work in machine shop) the same as couplings except no hole, will this work? They look different in the manual. Or can I buy them somewhere reasonable? thanks, Ken M
JD70Jim
08-09-2001 17:40:12
 Re: JD 70 Rocker shaft enable? in reply to Ken M, 08-09-2001 17:19:48
Almost any salvage yard that has letter series or first number series John Deere salvage tractors would have them. The dummy plugs are pretty common. It is the coupling for the hose ends which is harder to find and therefore more expensive. If you supplied the name of the state where you live, surely someone could suggest several of these places to you.
Ken M
08-10-2001 08:01:36
 Re: Re: JD 70 Rocker shaft enable? in reply to JD70Jim, 08-09-2001 17:40:12
I live in central Minnesota
poorerbut
08-10-2001 05:27:49
Jim:I still have to set the metering screw on
mine but I put Pioneer couplers in and leave them.
Do you still have to set the screw with the dummy plugs ? I don't remember. Rick.
JD70Jim
08-10-2001 06:56:24
 Re: Re: Re: JD 70 Rocker shaft enable? in reply to poorerbut, 08-10-2001 05:27:49
You have to set the metering screw. Hydraulic powertrol is a single circuit. It's either rockshaft or remote. I have never used the rockshaft on my 70. I don't have a 800 hitch for it, nor does it have aftermarket, so it doesn't get used. I fitted my tractor with Pioneer JD style couplers, mounted on the bayonet style original hose end couplers. I also have an original green JD cylinder with the old style couplers, which I will use for show, if I ever get an implement ready.
G Taylor old low pressure remote cylinder value?
08-10-2001 11:03:11
 Re: Re: Re: Re: JD 70 Rocker shaft enable? in reply to JD70Jim, 08-10-2001 06:56:24
How scarce & valuable are the old low pressure Deere remote cylinders in your part of the country? Is yours the "double" depth stop rod unit or the later cylinder with the "jam" lock on the cylinder rod as a depth stop?
JD70Jim
08-10-2001 13:35:31
 Re: Re: Re: Re: Re: JD 70 Rocker shaft enable? in reply to G Taylor old low pressure remote cylinder value?, 08-10-2001 11:03:11
Mine are the later, hydraulic stop type. The "mechanical stop" or "double rod" type are a little harder to find. I have seen the Hyd. stop type like mine go for $40 to $100, with $60-75 being most common. It all depends on how many people want to bid. The older ones that I've seen were around $50 and in well used condition. I really don't know what one would bring with new paint, seals and hoses. Mine are painted, have new seals, and new hoses, so I'd guess they were somewhat valuable.
poorerbut
08-10-2001 12:21:52
G : Good question. I have Dad's double rod that
came with the '49 "A" that I'm using on the disk.
Never really thought that it might be 'antique?'.
I haven't seen any sell for a long time. Rick
G Taylor sizes of old remote cylinders
08-10-2001 20:28:54
 Re: Re: Re: Re: Re: Re: JD 70 Rocker shaft enable? in reply to poorerbut, 08-10-2001 12:21:52
Did some rooting around & found some info in the 80/820/830,70D & 1010 parts manuals. There is a four inch dia piston low pressure cylinder with the double depth stop rods. Part # AR1304R up to serial # 4RC-55636 & part# AR1716R above.Has 6.6 tons of extend thrust. The modern looking low presure cylinder with the depth stop on the rod & little plunger is 3.5" diameter. Known as the 3.5x8. Part #AF2322R. Has 5.05 tons of push thrust. The high pressure cylinder has a 3.0" piston & 3.71 thrust on low pressure & 7.95 tons on a 2250psi system. Looks like fingers don't have a chance around any of them. Bought a 4" cylinder with ratty hoses & Deere pto air with melted babbit bearings & no hose together for $50.00 Canadian peso's.
poorerbut
08-10-2001 07:12:33
Same with me. I took the after market 3pt off
and put it on Dad's "A" just to move snow. Some-
body had broken off the metering screw on the "70"
and I had a rough time getting it out and replaced
I have it set for the remotes but couldn't remem-
ber if I set it in or out. Just thought Doc ought
to know about the metering screw. Rick
