JD B Push Rod Tubes, again-
Joe Fabregas
08-08-2001 19:19:54
43 B, suspect push rod tubes are leaking, oil is gray and overfull while antifreeze won't stay up. Are there two tubes or four. With valve cover off I can clearly see the inside ones, but the outside ones look more like holes in the head. How much meat is on a tube. Could I make up some puller arms like a large pilot bearing puller? Tempted to try alumiseal first, just don't feel up to pulling the head. Thanks, Joe in NY
Will
08-09-2001 21:32:54
 Re: JD B Push Rod Tubes, again- in reply to Joe Fabregas, 08-08-2001 19:19:54
There is only 2 tubes, The outer pushrod holes are drilled. You can easly make a puller for them. Just like pulling sleaves. Go ahead and pull the head. At first I thought I had a tube go, but it was the head gasket. More fun. On a 1943 B too. 141524.
Have fun, Will P
gary
08-08-2001 20:32:29
Pull the head and do it right,you will be glad that you did later.
