John Deere H speed
Rustin
08-06-2001 21:26:44
Does anybody know the speed that the JD H will travel in 3rd gear (road gear). Also what RPM's does the engine usually run?
phil
08-07-2001 10:23:21
 Re: John Deere H speed in reply to Rustin, 08-06-2001 21:26:44
Rustin, I have an owner's manual that says on the specs page that it goes 5.75 mph & the engine goes 1400 rpm loaded. On another page it says that the engine is set for 1400 rpm loaded and 1540 rpm fast idle. So I think the 5.75 goes with the 1400 rpm - then the speed would be about 6.3 at 1540 rpm. I set mine by timing it on the road, one mile in 9.5 minutes. You can also push the foot pedal & go about 7.5 mph at 1800 rpm, I seldom use that. Hope this helps.
