4010 Rear PTO Leak
Paul S.
08-06-2001 19:14:51
My 1963 4010 suddenly developed a massive HYD. leak at the rear PTO. I have replaced the rear seal and gasket which has slowed it down some. I am using the 540 RPM shaft to run my brush hog.
Any experience, ideas, etc. will be greatly appreciated. Thanks to all who reply.
Paul.....
Illinois Red
08-06-2001 20:26:25
 Re: 4010 Rear PTO Leak in reply to Paul S., 08-06-2001 19:14:51
Did you put on a new bearing quill with the new seal? Did you put the seal on with the lip facing in, spring side toward rear differential? Is the bearing good? Did you clean the gasket surface thoroughly? Is the stub shaft straight and not bent? Just a few ideas. Hope this helps. Good luck.
HTR
08-06-2001 21:00:11
 Re: Re: 4010 Rear PTO Leak in reply to Illinois Red, 08-06-2001 20:26:25
Also, did you remove the small snap ring and washer on the shifter rod, pull the rod out a few inches and replace the Oring.
