3010 piston options
dave
08-06-2001 12:44:00
I will be puting 4" 3010 pistons in my puller . are there any compresion options available in these models? Dealer shows lp and gas as same piston. High altitude? Are the compresion heights the same on gas and diesal?
Mike Aylward
08-07-2001 10:43:32
 Re: 3010 piston options in reply to dave, 08-06-2001 12:44:00
Dave, the gas and LP pistons are different. However, it is possible that only one or the other piston is currently still furnished. The LP piston will have a much shallower dish in the top and will increase the compression from around 7.5 to about 9:1. The last I knew LP pistons were still available, but not in a sleeve and piston kit. You will have to order them one "hole" at a time. Hope this helps. Mike
Don
08-06-2001 16:44:24
You can use 3020 piston and sleeves for an increase in bore.
