JD 60 Power Steering
Larry
08-06-2001 09:19:56
I converted my 60 from manual to JD power steering. The pump is rebuilt and seals in the pedestal are new. Steering is easy when turning left or right, but tends to get harder or bind when returning to the center position. I have the JD power steering manual. Also, is the wheel suppose to return to center on its own after turning? My steering does not return to center. Any help is appreciated. Thanks.
Chuck
08-06-2001 09:47:16
 Re: JD 60 Power Steering in reply to Larry, 08-06-2001 09:19:56
the wheel wouldn't turn to center on its own. The binding in the steering is probably due to wear on the worm and on the upper gear. You can loosen the gear and loosen the upper part of pedistal...raise it up and turn the gear 180 and you will be using an unworn area. Also you might have to a gasket or do minor adjusting after that.
