Drill sizes for DLTX34
Will P.
08-05-2001 14:07:12
What size drills do I need for the DLTX34 carb? Can't remember who has them too. Was at the web page and saw like 4 or 5 sizes and want to drill my carb out. Acting a little goofy. Rust in carb. Thanks to everyone that helps on this board.
Will P.
Larry L. Walla
08-06-2001 05:37:09
 Re: Drill sizes for DLTX34 in reply to Will P., 08-05-2001 14:07:12
I use a set of Acetylene welder tip cleaners. Be careful not to ream out the holes too large. You might change a "B" carb into an "A". Drills should be a last resort.
Deere2931
08-05-2001 20:33:18
Will, #40 and #53, and what Clooney said.
Bob
Clooney
08-05-2001 14:13:07
Will, I usualy use Mig welding wire first & the drill as a last resort. Be careful with the drills if you don't have the correct size you can alter the carb metering. Roberts carb has the correct drills, http://www.robertscarbrepair.com/tools.htm
