JD A Question info.
Mike in PA
08-02-2001 18:52:53
I recently bought a JD A tractor. It was made in 1950, but still has the 3 sp. trans with hi-lo range. I was told Deere changed to the single stick 6 speed trans during this year. Can anyone tell any more about this, can't find Deere Archives on the internet. Also, my A leaks oil onto the belt pulley and smokes pretty bad. Can anyone tell me where this is coming from and how to fix it.
Any info appreciated.
Thanks, Mike
Jim Stumpf
08-05-2001 14:58:54
 Re: JD A Question info. in reply to Mike in PA, 08-02-2001 18:52:53
IAW JD Data Book by Lorry Dunning, starting with #648000 (1949) had single stick shifter.
Kemper
08-03-2001 22:32:29
Mike, my A is a 1950 and it has the 6 speed trans, serial # 660857 they must have changed before this number, i get some smoke out of my belt pulley when i pull it hard,sounds like we both need an overhaul, hope this helps.
rollo
08-03-2001 05:16:09
Don't know when they changed over, but it sounds like you need a ring job and main bearing adjustment probably. I'd try a compression check first however to make sure that's the problem.
