Solenoid
Jon
08-02-2001 16:17:13
I just went to start my tractor and the solenoid just chatters or buzzes and the starter doesn't engage. The battery (8v)is charged up and I even jumped it with a 12v and got the same thing. Do I need a new solenoid or is it something else.
Thanks, Jon
Craig MN
08-03-2001 15:10:47
 Re: Solenoid in reply to Jon, 08-02-2001 16:17:13
Also be sure the solenoid is properly grounded. It may be grounded through its mounting lugs (remove and clean away rust, dirt, paint and remount) or have a separate ground terminal and wire.
Illinois Red
08-02-2001 21:48:37
Jon You could have a bad solenoid. First remove the wires and clean all connections then reinstall the wiring. Also make for sure your battery posts and cables are in good shape and clean.
