3010 brakes
Lloyd
08-02-2001 13:28:10
When I step lightly on the right brake, it feels like both brakes come on. If I push harder, the right brake does come on harder than the other one. The left side seems to opperate normally. I have replaced the pads and piston seals on the brakes.
Is this even possible? Does anyone know where to start looking for a cause for this?
HTR
08-02-2001 20:51:11
 Re: 3010 brakes in reply to Lloyd, 08-02-2001 13:28:10
If you have a later 3010 it is possible, as there are equalizing pins built into the brake valve. This was done for transport and gives equal brakes to both wheels even if one peddle is pushed down 1 inch and the other peddle is pushed down 2 inches.
What usually happens to cause your problem is the boot on the brake valve rod rots, lets water down to the brake plunger and rust holds the plunger down far enough to keep the equalizing pin down. When you hit the other brake peddle, you apply that brake and the stuck equalizer applies the other one.
If this is the problem, take the valve off clean the plungers and replace the Orings and install new boot kits.
It can be a little tricky holding the valve and brake peddles in the vice, but anybody can do this job.
Illinois Red
08-02-2001 21:51:58
 Re: Re: 3010 brakes in reply to HTR, 08-02-2001 20:51:11
Make for sure you properly bleed out the brakes. If you haven't bled them yet then go ahead and do it. It won't take five minutes.
