Are there different front hubs??
DRL
11-25-2003 12:19:28
Are the front hubs on a standard narrow front B different than the front hubs on a roll-o-matic? I replaced the standard narrow front pedistal on my 1948 B with a roll-o-matic pedistal that did not come with hubs. I used the hubs from the old front end, and the wheels seem to be spaced farther apart than what they should. I have looked at several pictures of roll-o-matic front ends, and the wheels on all of them seem to be closer than what mine are. This wouldn't be too much of a problem except that the wider spacing is causing the tractor to steer harder than it should. Been through the whole front end using the repair manual and all the good info on this forum. Everything is adjusted as it should, but still steers hard. This is why I suspect the wider spacing.
John T
11-25-2003 19:16:11
 Re: Are there different front hubs?? in reply to DRL, 11-25-2003 12:19:28
DR, we discussed this topic for an A a while back on here or Rummys??? (I had the same problem on an A I had) On the A it has hubs that will still fit the spindles and work, but on the rollo o matic versus non, they are deeper. Also, there was a difference depth (offset) of steel wheels that still fit the hubs but set out more. Im not sure, but suspect the B's may be similar.
John T
Clooney
11-25-2003 13:10:22
DRL, probably.. There are a ton of wheel listings & hub offerings for that era B.. A quick look tells me that you probably have 2379R hubs & there is a good chance that your R-O-M needs the 2791R hubs.. There are also a few different wheel listings..
~What did your R-O-M come off of?..
~Can you find any casting numbers on your hubs?
~Can you find any stamping numbers on the wheels?
~I have an old Roll-O-Matic B out in the back barn, let me know & I can send you some close up pictures of the hubs & wheels [too dirty to get any numbers for you]..
[email protected]
