Can babbited rods be machined to use inserts. Model B
Bob Weber
08-02-2001 08:26:46
An earlier post made me wonder if this can be done. If not, how tough is it to have a set rebabbited?
Thanks!
Gman
08-03-2001 22:12:01
 Re: Can babbited rods be machined to use inserts. Model B in reply to Bob Weber, 08-02-2001 08:26:46
Bob I'm having a set bored for a B that I'm repairing for a neighbor at Somerset Machine Shop in Somerset,Ky now. $40.00 a Rod an inserts installed plus notch for bearing retaining.You might have to use the thick shim,cause you could get into bolt hole when you bore to get them round.Gman
Chuck
08-02-2001 09:04:20
I've worked on many B's and have alway used 50 rods. I believe getting the rods would be less than having machine work done. If you're working on an A I'd say 60 rods would work. Check it out.
