Connecting rods JD model A
Ron Sharpe
07-31-2001 17:04:43
I took the cap off of the connecting rod to inspect the bearing, but to my suprise there was no bearing. What's going on?
Clooney
07-31-2001 17:23:02
 Re: connecting rods JD model A in reply to Ron Sharpe, 07-31-2001 17:04:43
Ron, I'll bet that there is a bearing in that rod. Some of the old J.D.s use a babbit type bearing that is poured in the rod & is actually part of the rod. If you look closely you will see a softer babbit type meterial & shims between the cap & rod. Adding or removing shims is how the clearance is set.
Ron Sharpe
07-31-2001 21:17:34
 Re: Re: connecting rods JD model A in reply to Clooney, 07-31-2001 17:23:02
Clooney you were right again. Thanks Ron
