630 power steering leaks
Roger
11-25-2003 10:32:43
i am working on some power steering leaks on 630 after running it begins to bubble out the top. what is the cause of this? how do i fix it? please help. thanks!
Clooney
11-25-2003 11:59:18
 Re: 630 power steering leaks in reply to Roger, 11-25-2003 10:32:43
Roger, it is probably sucking air in from somewhere,, probably one of the pump seals.. If not there, then maybe a leak or pin hole in the return line..
[email protected]
roger
11-26-2003 10:17:35
 Re: Re: 630 power steering leaks in reply to Clooney , 11-25-2003 11:59:18
clooney, washed off all the fittings and pump to check for leaks, if there was a bad pump seal or pinhole would it also leak fluid out? is there a check valve that may not be opening on a return line? as it is only overflowing once in awhile. Roger
Clooney
11-26-2003 12:23:16
 Re: Re: Re: 630 power steering leaks in reply to roger, 11-26-2003 10:17:35
Roger, you ask...."if there was a bad pump seal or pinhole would it also leak fluid out?">>>>>> Not necessarily so.. Air leaks easier than fluid & if you have a seal leaking it could allow air under the seal during operation but push the seal tight with a slight fluid pressure. Or your rear pump seal could be leaking & that is inside the fan tube..
~A pin hole or fitting leak above fluid level could suck air in but not leak fluid out..
