JD 4630 alternator
Steve
07-31-2001 06:32:32
A friend has a 4630 the alternator is not connected, previous owner cut the wires. Need to know what wires go where. Alternator has a screwpost that I figure goes to a voltage reg? Other wires are a plug with 2 wires, one marked F, the other marked R. Any help would be appreciated.
rob australia
08-02-2001 06:32:19
 Re: JD 4630 alternator in reply to Steve, 07-31-2001 06:32:32
yep i have a 4630 the two wires go in the top of the alternator red to the outside
Don
07-31-2001 14:02:45
The regulator is inside the alternator.The heavy red wire goes to the large post, the resistor wire goes to the "r" terminal and the small red wire goes to the "f" terminal. you can get a terminal end for the wires from your dealer. Don
