JD-DLTX-71 CARB
Scott
07-30-2001 20:11:31
Could someone help please? I'm wondering does it make a difference as to the direction that the holes in the main jet are located in relation to the choke or throtle plate? Or can the jet be put in any position.
Also, how critical is the fit between the end of the main jet(where the spring shoulders against it) and the bore of the carb body? Is the fit here ment to seal gas from the outside of the jet? I believe that air is brought in to this area form in front of the venturi, is this correct? Thanks for any help, Scott
Clooney
07-31-2001 02:42:38
 Re: JD-DLTX-71 CARB in reply to Scott, 07-30-2001 20:11:31
Scott, the hole direction makes no difference, the fit of the main jet should be loose enough for the jet to slide in easily (if it has a little side clearance it shouldn't hurt but too much will change the calibration). Air enters the vent system at the rear of the carb the air passage that runs to the ft of the venturi is for the "ecominizer system" & allows the manifold (negative)pressure to alter the atmospheric pressure that pushes on the fuel in the float bowl to lean the mixture at high vacuum light loads for higher fuel economy.
Scott Gooding
07-31-2001 13:37:13
 Re: Re: JD-DLTX-71 CARB in reply to Clooney, 07-31-2001 02:42:38
Thank you, for the info, Clooney
