52 A rod end lube
Ron Sharpe
07-30-2001 19:13:05
How is oil supplied to the rod ends? Is it the same line that feeds the main bearings? I need to know because I am replacing the main bearing on the fly wheel side because of a broken oil line, and am wondering if the rod bearing on the same side may have been starved for oil as well.
clooney
07-31-2001 03:56:03
 Re: 52 A rod end lube in reply to Ron Sharpe, 07-30-2001 19:13:05
Ron, the rod bearing is supplied oil from a drilling in the crank from the main bearing supply on each side. You should pull the rod bearing & inspect it.
Ron Sharpe
07-31-2001 03:59:56
 Re: Re: 52 A rod end lube in reply to clooney, 07-31-2001 03:56:03
ok thanks clooney
