Behlen Road Gear
Just Curious
07-30-2001 11:28:49
would like to know what years this option was available on the early JD's and was it a factory option or added by an after-market mfg. any other info you may have on this topic would be appreciated; i.e. when did they stop mfg. this option, what JD's was it available on, etc., etc. and do any of you happen to have owned or now currently own a JD with this option on it?
phil
07-30-2001 18:03:29
 Re: Behlen Road Gear in reply to Just Curious, 07-30-2001 11:28:49
In the 40's & 50's, I used a 1938 A that had a Behlen 5 & 6. As Bob said, you put the trans in neutral, engage the Behlen lever, then use the Hi/Lo lever for 5/6. If you happened to forget to put the trans in neutral, it was locked in 2 gears at once and the tractor would not move. The Behlen Box was about 12"X12"X3", mounted on the left side behind the flywheel. Sixth went about 18 mph, a little faster than the later, factory equiped tractors (such as 1946,7,8), Tractor is still in the family - I hauled it a few hundred miles for my uncle this spring.
JD Ol' Timer
08-03-2001 12:40:11
 Re: Re: Behlen Road Gear in reply to phil, 07-30-2001 18:03:29
Now I know why some of those older JD's seemed to fly down the road! When I was a kid (before computers & the internet!) I always wondered why some of those JD's could outrun a Farmall; now I know how they did it!
Just Curious
07-30-2001 21:47:14
thanks for the info guys, but I was familiar with the operation of the road gear, I needed to know where & who installed it.. was it at the JD factory, JD dealer, or did Behlen install it at their factory, or could anyone install it.. thanks
Poor Farm Jim
07-31-2001 11:49:34
 Re: Re: Re: Behlen Road Gear in reply to Just Curious, 07-30-2001 21:47:14
I can assure you that Deere did not ever send a tractor out of their factory with the Behlen setup. It was strictly after market. I'm sure most were installed by J.D. dealers, some by repair shops and a few by industrious, hands-on type owners.
poorerbut
07-31-2001 08:50:22
As near as I can remember (I was pretty little and
that was a LONG time ago) the neighbor,Red Weaver,
had a local tractor repair shop order it from
Behlen, and Carl Wysong installed it in their
shop. I remember the silver plate behind the
flywheel and how that old "A" flew !!!
BobTGS
07-30-2001 12:52:27
The Behlen Road Gear was an add on gear box sold by the Behlen Co.I know they were available for unstyled As,Bs,and early styled 4 speed Bs.They were operated by putting the tractor's trans. in neutral ,and using the tractor hi-lo shifter in conjunction with the Behlen box for fifth and sixth gears.Bob,from Triple G Service.
