40 T Electronic ignition problems
Daniel
11-25-2003 09:39:04
I recently converted my tractor from 6 volt to 12 volt and changed it to electronic ignition at the same time. (paid someone to do it).
When I took it to him it was running fine but the generator was bad so I decided to make all the changes at the same time.
Now it is only running on 1 cylinder. When you replace the points and condensor with electronic ignition do you need to adjust the timing?
The cylinder still has good compression when checked with a gauge so no stuck valve.
I am at a loss and any help on this would be greatly appreciated.
Thanks,
Daniel
Bus Driver
11-25-2003 16:21:01
 Re: 40 T Electronic ignition problems in reply to Daniel, 11-25-2003 09:39:04
It is remotely possible that by coincidence a valve has stuck. If stuck closed, the pushrod may now be bent. Pull the valve cover and check the valve lash.
ChuckW
11-25-2003 13:07:52
my local dealer was installing a unit recently. I had introduced them to electronic ignition. The unit was having same problems as you've noted, the problem was they had installed the wrong, I repeat wrong kit. Check this out, as the donut trigger/kit has to be the correct unit.
John T
11-25-2003 13:22:22
 Re: Re: 40 T Electronic ignition problems in reply to ChuckW, 11-25-2003 13:07:52
Chuck, I can believe that happens for sure. The bottom line is the magnet that fits on the rotor has to pass by the pick up coil at the same time and orientation where the high cam lobe on the rotor used to open the points, but we cant tell what he has from sitting here. John T
Clooney (cap picture)
11-25-2003 12:46:56
third party image
Daniel, look at the attached picture & see if your wires, cap, & distributor position look like the picture.. If not & your wires are reversed then your non firing plug is probably not sparking at the correct time..
~Due to the 180�/ 540� firing of the Deere 2-cylinders & the distributor rotation characteristics on the Dubuque tractors the caps are a bit different than on other engines & that means the plug wires must be in the correct spot in the cap to fire both cylinders at the correct timing..
[email protected]
John T
11-25-2003 13:18:17
 Re: Re: 40 T Electronic ignition problems in reply to Clooney (cap picture), 11-25-2003 12:46:56
Clooney, you think its possible he has his lagging (second) terminal plug wire going to the leading (first) cylinder but the whole distributor is somehow advanced 90 degrees (which would be 180 of crank timimg)??? Im not even sure if thats mechanically possible from the distributor mounting into the engine????? (Can it physically mount 90 advanced???) If that were his case the first cylinder could fire when its supposed to but the rotor tip wouldnt be at a tower when the coil fired 90 distributor or 180 crank later????
I dont know if it was workign but then this happened, if so thats NOT the situation and maybe he has a bad plug or wire or a cap problem.
I think you can have the wrong cap that would still fit down onto that distributor, but not sure, no parts book or CD here.
John T
Clooney
11-25-2003 13:36:36
 Re: Re: Re: 40 T Electronic ignition problems in reply to John T, 11-25-2003 13:18:17
John, I believe part of what you said is what's happening & that is it's possible the second plug wire might be going to the first plug. The second wire is sparking according to Daniel so the rotor is at least pointing to the other cap tower when the coil fires..
~If the distributor is timed incorrectly & the #2 plug wire is going to #1 that would mean the #2 would spark at the incorrect time to fire #2 on compression.. That's why I posted the picture,, those Dubuque's usually have the distributor installed about where the picture shows & the wires run as shown.. It was a lot easier to post that than try to explain it..
~There are other alternatives & one is that he has the incorrect reluctor ring in the distributor.. But since he has a spark on both plug wires it is at least tripping the hall effect as the rotor lines up with the cap.. It sure sounds like the cap just isn't lined up correctly with the non firing cylinder TDC on compression.
~The other alternative is that he has no compression on the non firing cylinder.. Or other mechanical problem..
[email protected]
Daniel
11-25-2003 15:19:56
 Re: Re: Re: Re: 40 T Electronic ignition problems in reply to Clooney , 11-25-2003 13:36:36
Thanks,
For the help I am going to take all the info and give to the mechanic working on it.
First the tractor was running fine on six volt with points. The cap, plugs and wires have been replaced and a compression test was done on the cylinder in question with good results (more than the cylinder running). The picture from clooney is exactly what mine looks like. And the mechanic said he did not remove the distributor.
Could it be:
1. BAd coil
2. Bad ignition
3. bad installation
Thanks for the help and if you think of anything else please post.
Daniel
Clooney
11-25-2003 19:55:31
 Re: Re: Re: Re: Re: 40 T Electronic ignition probl in reply to Daniel, 11-25-2003 15:19:56
Daniel, if yours is exactly like the picture then the cap & wires are set up correctly so that is probably not the problem.
~You ask..
Could it be:
1. Bad coil>>>>>> NO, the coil fires the same for both plugs so if one works the coil is good..
2. Bad ignition>>>>>> If by that you mean Ign switch? Again, NO..
3. Bad installation>>>>>> That is always a possibility but if BOTH plug wires spark it was probably the correct parts installed correctly.. To verify that, take a[known good] spark plug & open the plug gap to 3/16" [use a 3/16" drill bit as gap gage], then install that plug in one wire at a time & lay on the engine block, turn the ignition on & crank the engine... If you see a bluish spark jump that gap when hooked to both the good & bad wire your installation is probably good as you are getting a spark as the rotor lines up with a correctly installed cap & wires.
~If you pass the above spark test I would have to say we are back to the beginning & you really should try another new spark plug in the bad cylinder..If it still won't run on that cylinder give that cylinder another compression test..
~If it still won't pull on that bad cylinder we are going to have to figure out a way for you verify that your spark is occurring a the correct time on the bad cylinder.... What cylinder was that again?
[email protected]
John T
11-25-2003 19:28:43
Daniel, the SAME coil and SAME electronic switch should fire out BOTH cap terminals. Therefore, if one fires good, the coil and switch are working and the possible differences may be the cap or plugs or wires or how the magnet encircling the distributor shaft (around the cam lobes) passes next to the pick up unit cuz its passing is what triggers the switch to fire the coil.
1) Bad Coil????? NO
2) Bad ignition ??? NOT the switch part, BUT MAYBE in the area where the magnet passes by the pick up coil on the distributors base.
3) Bad Installation??? That may well be the case, especially regarding where the magnet on the ring around the cam is located and/or the mountign and location and orientation of the pick up coil on the base plate. The magnet MUST pass by the pick up coil in the same time and place on the base where the points would have opened on high cam and the rest of the distributor be in time so the leading cap terminal gets fire first, the lagging terminal 180 of crank or 90 of distributor shaft rotation later. Of course, at teh time the rotors tip is in line wiht the internal part of teh cap tower.
I still wonder about the cap being right and the distributor in time meaning its set up so the rotor lines up with the leading cap terminal when its at TDC on its compression power stroke and the magnet passes by the pick up coil, ad 180/90 later, it repeats on the lagging cap terminal to fire that plug when a magnet again passes by the pick up coil.
John T
Clooney
11-25-2003 11:56:19
Daniel, seeing as it was just worked on & an electronic ignition pick up was installed & also new plugs were installed you might want first pull BOTH plug wires & stick a nail or other metallic item in each plug wire & hold them up to within 1/8" the cylinder block & MAKE SURE you have a spark for each wire.. If you don't, suspect the distributor pick up was installed incorrectly or the distributor was re-timed to the wrong cap tower.. If it was timed to the second cap plug tower & the wires were moved to compensate for that, then the non firing cylinder could have the rotor to the cap contact not lined up at firing time..
~If you only have spark at one wire then pull the coil wire & hold it to within 1/8" of the block & crank the engine.. If you get 2 sparks in a row there on every other revolution then suspect the above.. If you only get one spark there for every 2 revolutions of the engine suspect the pick up or reluctor ring was installed incorrectly, or some other problem with the E.I. installation...
~If you get a nice spark from each plug wire, then install new spark plugs [a common problem on the Dubuque tractors but the H.I. should have helped that problem]..
[email protected]
John T
11-25-2003 10:19:05
Duane, when you switch to an electronic ignition, timing is still a necessity of course, which may or may not have required adjustment (after the changeover) cuz it depends on the location of the magnetic trigger on the rotor (sort of like what it did on high cam with points open) and the location of the pick up coil on the distributors base. HOWEVER, if shes not firing on one cylinder which still has good compression and valves are correct, a minor timing adjustemnt isnt gonna fix that.
1) The first thing I would do is swap plugs and plug wires to see if that makes the other side miss??? If so, then you either have a bad plug or a bad wire. So long as BOTH cap terminals can produce an equal spark, then its not a cap or rotor problem, but more likely a wire or one of the plugs is bad. The swap tests can easily eliminate if one (plug or a wire) is bad.
2) If swapping plugs or wires makes no difference and its still only one side that dont fire, the problem could be in the distributor cap or rotor like where only 1 terminal is hot and the other one never produces a spark.
3) Remove the cap and check the condition of the rotor tip and the inside terminal which never fires, and look for a crack or a carbon track or something different (broken cap or insulation or brass terminal) on the terminal that wont fire a plug. Again, this assumes that one particular cap terminal wont fire a plug, regardless which wires or plugs are used.
4) The same coil and same pick up unit on the distributors base fires BOTH plugs, so if one fires good but not the other, the problem has to be in a magnet on the rotor or the plug or wire or cap or rotor.
5) Inspect the magnets that are encircled around the rotor, they replaced the job of the high cam lobes. If misisng, it wont trigger the pick up unit and fire the coil and the plug leading to the cap terminal where the rotor tip is pointing then.
6) Remove the plugs with their wires attached but sides againt frame ground and turn her on and crank her over and see if BOTH produce a good visible blue and NOT a faint thin wimpy yellow spark. Same as above, if one is weak or dont fire at all, change it to the other side to see if its a good spark then. If the spark is then weak on what was the good side before (but you didnt swap wires) I would suspect that plug, especially if the plug from that side still made a good spark over on the other side.
7) If its still always the one side thats weak regardless what plug or wire is used, then see above for a possible cap or rotor or magnet on the rotor problem.
When you went from 6 to 12 volts, did you get a new 12 volt coil or add an external ceramic voltage dropping ballast resistor???? If not, the coil can overheat and eventually degrade BUT if its onyl 1 side thats a weak spark, dont sound like thats the problem since the same coil fires both plugs.
If you get BOTH sides making a good similar spark but she still misses on one side, post back and we will go from there.
If only 1 side has a good spark, I suspect the plug or plug wire or a cap or rotor problem (cracks, carbon, broken insulations, broken internal connection between inside and out of terminal) or a magnet on the rotor problem. Again, swap plugs and wires to insure its just that ONE cap terminal thats not hot and if so, look at the cap n rotor or magnet. THIS ASSUMES THE MISSING CYLINDER HAS EQUAL COMPRESSION AND VALVES AND VALVE TIMING ARE CORRECT. IF NOT, POST BACK.
BE SURE BOTH PLUGS AND BOTH WIRES ARE GOOD AND REPLACE ANY THAT ARE SUSPECT OR APPEAR FOULED OR CARBONED OR COATED AND TRY THAT FIRST.
Post back any questions or e mail [email protected]
God Bless ya
John T
Daniel
11-25-2003 10:50:20
 Re: Re: 40 T Electronic ignition problems in reply to John T, 11-25-2003 10:19:05
In waiting on the mechanic I have replaced the plugs with aut0lite 216s, The wires from brillman's and the cap. I am geting a spark from wires but it must be firing at the wrong time. The tractor is only running on the front cylinder. You can disconnect the rear plug wire with no effect. I f you do the same on the front then the tractor dies. It has very little power now. But before I took it for the change it was pulling a two bottom plow.
Can it be the timing if it starts as ssona s i pull the starter? No hesitation at all. But only on one cylinder. I think I may have gotten a bad ignition. I may try switching back to points and adjusting the timing.
Thanks,
Daniel
John T
11-25-2003 11:59:39
 Re: Re: Re: 40 T Electronic ignition problems in reply to Daniel, 11-25-2003 10:50:20
Daniel, dont trash that electronic ignition yet, if working it provides more spark energy than the old points, plus as Wayne and others more familiar with those tractors keep saying, they are bad to foul plugs. Just try some plug and wire swaps to insure BOTH cap terminals produce a similar spark. If not or if one terminal isnt making spark at all (with any plugs or wires), its plug sure cant ever fire. If the cap and rotor are both good but she only fires when the rotor is lined up with one terminal but not the other, suspect the rotors magnet cuz it has to pass by the pick up on the base to trigger that electronic ignition. You sure BOTH plugs are good???
Hang in there, the bottom line of course, is both plugs have to fire their respective cylinders at TDC, the left fires and then 180 crankshaft degrees of rotation later the right does and then you have the 540 coast cycle before left is back at TDC on its compression power stroke again.
Have both plugs out (hooked up and grounded) and simply watch if the left fires then the right 180 later as it has to.
John T
Wayne in Tn.
11-25-2003 11:13:41
Daniel, I would start out as John T. says, go for the spark plugs first. Those Dubuques are known for fouling a plug. They can make even a new one go bad quick.
