Hand clutch
ron sharpe
07-29-2001 23:56:14
On my 52 model A JD I would like to take the brake out that is run by the hand clutch, and put a bushing in it to take out the slop,because it is so loose. What do I have to take apart to get it off?
Chuck
07-30-2001 05:34:56
 Re: hand clutch in reply to ron sharpe, 07-29-2001 23:56:14
Ron, Clooney is right on target, but did you release the clutch before trying to remove the block. You need to do this so there is some movement and you can get the fork out. Be careful putting it back in as to get it located in the right place.
Ron Sharpe
07-30-2001 06:29:35
 Re: Re: hand clutch in reply to Chuck, 07-30-2001 05:34:56
Thank you gentelmen I'll try again.
Clooney
07-30-2001 03:10:55
Ron, just pull linkage pin & the 4 bolts & then the ft bearing assy.(the bearing is the cover on the ft of the 1st reduction cover that has the brake, & clutch fork in it). Once it is off there is a C clip that has to come off then the fork shaft can slide out the top. Make sure you mark the fork to shaft before removal. You will find that brake arm hole has worn egg shaped so you will have to machine it out round before installing a bushing.
ron sharpe
07-30-2001 04:01:03
 Re: Re: hand clutch in reply to Clooney, 07-30-2001 03:10:55
Clooney I took the four bolts out and the linkage pin but the plate dosen't want to come off it comes loose but not off .Wich is the first reduction cover?
Clooney
07-30-2001 16:46:54
 Re: Re: Re: hand clutch in reply to ron sharpe, 07-30-2001 04:01:03
Ron, sorry for the delayed responce my power has been out all day. I think Chuck answered your question, I should have mentioned that in my first post. If you still have trouble getting it out you might have to wiggle it up & down & pull it out at a slight angle to get the fork pivot bolts to clear the hole.
Ron Sharpe
07-30-2001 19:01:43
 Re: Re: Re: Re: hand clutch in reply to Clooney, 07-30-2001 16:46:54
Thanks Clooney I got it out, my problem was that I hadent taken the clutch out of gear. Once I did that it came out easily. Now tonight I will take it to work and bore it out and bush it.
