JD 60 Main bearing Question
lee
07-28-2001 19:26:01
I have a 60 that I'm getting the crank ground down. I have new sleeve bearing for the tractor. What is the most I will be able to get it ground down so the bearings fit. I don't have shims so I can't ajust them like the old A's
Clooney
07-28-2001 19:45:13
 Re: JD 60 Main bearing Question in reply to lee, 07-28-2001 19:26:01
Lee, you will probably have to press the new bearing in the bearing housing then mike it to know how much you have to work with. If you have a "one size fits all bearing" I don't know what size it is after pressing into the housing. You might have to call one of the crank grinding companies to see what the limit is. I usually turn the crank until it is round & has no defects in it then bore the bearing for running clearance.
lee
07-28-2001 19:56:52
 Re: Re: JD 60 Main bearing Question in reply to Clooney, 07-28-2001 19:45:13
Thanks Clooney =)
