Help ID JD Plow
GregS
07-27-2001 16:55:13
My uncle just purchased an old JD trail 4-14 plow and would like to know what model it is. Unfortunantly it is in pretty ruff shape and I could not find any numbers in any of the beams. The plow is on all rubber and has one arm to adjust the wheel in the furrow. The draw bar has a clevis to hitch plow to tractor. It has a main beam that connects all the trusses. The JD decal is still on this beam. The shares are the four bolt kind and the moldboards have a decal or number painted on them that reads HS 434 NC.
The mold boards are the trip kind much like the f145 plows
He would also like to know if the hubs are yellow or green.
Any help would be greatly appreciated.
Greg
BILL DITTMAN
02-17-2002 08:53:54
 Re: Help ID JD Plow in reply to GregS, 07-27-2001 16:55:13
I have a plow with the same description and don't know what johndeere model # it is ? have u found out any thing yet ? my furrow wheel is small but on rubber and it is i guess same age as the year of the model 70 or 720 tractors or maybe the r's , but i also would like to find an owners manual for it . hopefully some one can help .
Larry
07-28-2001 08:35:22
Is the main beam small and solid or larger square tube? I'm assuming it is hydraulic lift. What size is tail wheel and can you find any part numbers on the steering parts on tail. I should be able to figure it out.
GregS
07-28-2001 15:13:33
 Re: Re: Help ID JD Plow in reply to Larry, 07-28-2001 08:35:22
The main beam is about 2 by 2 solid steel. The rear wheel is 4.00 x 12 but I will not be able to get any numbers until after the weekend. By the way, it is hydraulic lift. Forgot to mention that the first time.
