2020 diesel w/ fluid in oil
DuaneD
07-26-2001 18:35:47
I have a 2020 diesel that began overheating. Noticed that oil was foaming out the dipstick and then drained about 4.5 gal of fluid out the oilpan. It doesn't appear to be coolant because the radiator is topped off. Can it possibly be hydraulic fluid???? Do I have a cracked block/blown head gasket - or is it something else?
Don
07-27-2001 09:08:51
 Re: 2020 diesel w/ fluid in oil in reply to DuaneD, 07-26-2001 18:35:47
Does the oil smell like diesel fuel ? the injector pump can leak from the shaft seals and do this also. Don
DuaneD
07-27-2001 11:39:16
 Re: Re: 2020 diesel w/ fluid in oil in reply to Don, 07-27-2001 09:08:51
Nope. Looks, feels, and smells more like hydraulic fluid.
Don Robinson
06-17-2002 18:08:07
 Re: Re: Re: 2020 diesel w/ fluid in oil in reply to DuaneD, 07-27-2001 11:39:16
If the tractor has a seperate hydraulic pump for the power steering, there is a freeze like plug on the back of the power steering pump that is leaking. You have to take the pump off and re-seal the plug with JB WELD. Also prick punch the housing around the plug before applying JB WELD. This type system uses hydraulic oil from the tractor. I have had this happen twice. The last time it was a new pump. Good luck
HTR
07-26-2001 19:24:16
The first 2020s had open center power steering, with a small gear pump mounted on the timeing gear cover. If the seal is blown on the pump drive, it will fill the crankcase with hyd. oil in a matter of minutes. If the pump is beyond repair, they are not cheap $1000.
DuaneD
07-27-2001 04:55:10
 Re: Re: 2020 diesel w/ fluid in oil in reply to HTR, 07-26-2001 19:24:16
I'm sure that's the problem - I have an early model and the steering has been "whining" slightly. Hope it's fixable! Thanks for the info!
