52 B Need a generator
Alan Baldwin
07-26-2001 15:36:52
What I need to know is did they make a 12 volt generator? And if they did where could I locate one to fit on the B I just bought its 12 volt now but doesnt have a generator on it and I would perfer to stay with the 12volt system. Thanks Guys.
JDMO
07-27-2001 05:13:10
 Re: 52 B Need a generator in reply to Alan Baldwin, 07-26-2001 15:36:52
Alan, I got a starter shop to change the field coils in a JD440 starter motor to 12 volt. It worked fine in a 12 volt system. There are those that claim you can just use a JD original 6 volt starter in 12 volt systems without any problems.
Bill {AntiqueAcres}
07-27-2001 06:09:08
 Re: Re: 52 B Need a generator in reply to JDMO, 07-27-2001 05:13:10
It is in fact true you can use 12v on a factory 6v starter without any implications. The only time you will have trouble is if you don't know how to let of the switch and get it too hot, but that is true with any starter. Bill {Antique Acres}
Don
07-26-2001 19:48:36
The later styled A's used a 12 volt generator. I would bet they would bolt right on to your tractor. It would be worth looking into. I have a 1948 B I converted to 12 volts, but I used an alternator rather than a generator. Works good and less expensive than a generator.
Ron Sharpe
07-26-2001 19:47:00
Allan I have 52 model A and it has a 12 volt generator on it.
Alan Baldwin
07-26-2001 19:53:54
 Re: Re: 52 B Need a generator in reply to Ron Sharpe, 07-26-2001 19:47:00
Thanks I have one spotted from someone on here they guarantee it to work on my B thanks again Alan
GEMALO
07-28-2001 15:26:50
 Re: Re: Re: 52 B Need a generator in reply to Alan Baldwin, 07-26-2001 19:53:54
I have a 48 B that I just rebuilt.
The 6v system was a little weak for the motor. I went to the local automotive electrical shop , had the regulator changed to 12v and
put in a 12v battery, Now I have a 12v 48 B John Deere that looks original but cranks much better.
Good Luck!!!!!
