John Deere Starter question
Ed
07-25-2001 13:36:20
Hi,
I have a John Deere LT133 lawn tractor.
I'm having a problem with the starter not stopping after engine starts. The starter disegages from the flywheel most times
but keeps running. What controls this ?
Another problem, I'm not sure if related or not, the battery is not getting charged when engine is running.
Is that a bad solinoid causing that ?
Thanks for any advice,
The grass is getting higher..... help!
Ed
RV
08-13-2001 07:13:36
 Re: John Deere Starter question in reply to Ed, 07-25-2001 13:36:20
Have LT133 myself. I do believe the charging system has a recall with an optional update for a headlight switch. Call the dealer for updates.
Spokerd1
07-25-2001 16:43:32
Check the key switch, Might be not returning to the run position. This will keep the solenoid turning the starter over. The solenoid might be bad and hanging up. As for it not charging check the electronic regulator. You will run backwards at the price. Good hunting.
