Compression release levers
Tom Gardner
07-25-2001 10:39:34
Replacing the Champ D23 plugs with Autolite 388 seems to have cured my hard to start problem. A local JD oldtimer told me I should be starting my B with the compression levers opened. He said this will save me greef/money later with my starter. Is it normal for oil to drip out when you first open these levers? On my 51 B they are underneath the tractor.
Spokerd1
07-25-2001 16:46:38
 Re: Compression release levers in reply to Tom Gardner, 07-25-2001 10:39:34
He is right and do use the compression releases. It will save on the wear and tear on the starter. As for the oil it is a mixture of gas and oil. This is normal.As the compression release is pointing down, as a low point drain in a line.
