3010 PTO problem
Charles Jackson
07-24-2001 13:41:36
3010 Diesel PTO will not stay engaged. After it
kicks out-wait a few seconds and it will re-engage. Do I have to split the tractor to fix
the problem? Thanks.
Mike
07-24-2001 22:07:37
 Re: 3010 PTO problem in reply to Charles Jackson, 07-24-2001 13:41:36
Put your ear on both sides when you engage the pto. Sometimes you can determine were the problem is. As Tucan Sam says the nose always knows. But you might need a ear too.
Junkman
07-24-2001 14:10:26
Charles, Under the dash is the adjustment rod for the PTO. You can try shortening it some which will make it harder to engage (also harder to disengage). If that doesn't work I would say split it. I split mine this past February and it wasn't that bad. Try to find the jig to hold the front half up. Good luck! John
