Converting '47 B narrow front to wide front
Brewster
07-23-2001 20:14:48
I'm looking to buy a 47 B with a narrow front (not Roll-a-Matic) and I want to convert it to a wide front, what do I visually look for to determine if this is possible and will a wide front from an A fit a B? Thanks ffor the help.
phil
07-24-2001 19:51:11
 Re: Converting '47 B narrow front to wide front in reply to Brewster, 07-23-2001 20:14:48
Cultivated corn with a 1950 BW (brand new). It took about 16 rows to make a U-turn with it - the wide front wheels don't turn very far, about as much as a car. It was returned to the dealer to get a narrow frontend within weeks, and it had a happy life as a narrow B. Your narrow front '47 w/o Rollamatic is a nice setup, steers much easier than a Rollamatic, turns on a dime, fits in a narrow spot in the shed. But, if you want to change it, you'll need a 2-piece pedestal - one that comes apart where the front-wheel assembly bolts to the tractor. It's possible that the '47 could already have it, some were delivered that way.
Karl Bader
07-24-2001 17:13:04
Just out of curiousity why do you want to convert it?
You need not only the wide front but the pedestal as well. I've seen wide fronts go for about $2000
Hope this helps!
Karl
ET
07-24-2001 05:31:25
You need a two piece pedistal to install the wide
front. The round axel off an A will fit.
