620 Gains Oil
Duben
07-23-2001 16:15:20
My 620 seems to gain oil. Anyone have any idea what is going into the crankcase?
Gator
07-23-2001 19:16:47
 Re: 620 Gains Oil in reply to Duben, 07-23-2001 16:15:20
Clooney is right, see what is getting in the crankcase first then you'll know where to spend time and/or money. If it's gas it maybe the diaphrams in the top of the settling bowl need replacing. That is fairly easy to fix. Good luck.
Clooney
07-23-2001 17:42:46
Duben, thats an easy one, see what is loosing oil. It is either trans oil, power-trol oil, coolant, gasoline, power steering oil, rain water or someone is playing games with you.
Duben
07-24-2001 20:59:39
 Re: Re: 620 Gains Oil in reply to Clooney, 07-23-2001 17:42:46
Thanks Clooney. Turns outits power steering fluid.
Gman
07-24-2001 08:56:41
620 check the fuel shut off,the 50,60.70 had a troublesome fuel shut off that caused problems.You can check your oil first and see if its got a strong gas smell if it does change out the fuel sediment bowl assembly. Gman
