NOISY 3020 PUMPS WHATS UP?
BIG JOHN
07-23-2001 15:22:59
My pump makes a growl or a zeeeee e noise when running, is this common for the 3020. everything woks fine. pitch of noise changes when lifting 3pt.
Mark A
07-25-2001 12:05:19
 Re: NOISY 3020 PUMPS WHATS UP? in reply to BIG JOHN, 07-23-2001 15:22:59
Check the rubber bushings at the front of the crankshaft where the aluminum coupling connects to the hydraulic pump. Make sure the bolts are also tight as you dont want it flying off into your radiator!
JDTECH
07-23-2001 19:54:34
Make sure to check the pump drive. If the coupler is loose or the bushings in the aluminum coupler are worn, it will be noisy untill a hydraulic function is activated, such as steering, 3pt, remotes. Also check the bolts that clamp the drive shaft to the pump shaft. If they are loose, you should also check the splines. Good luck!
john2510-3020
07-23-2001 19:52:21
it is comman for any jd of that vintage to whine like that. all my tractors(2510, 3020,4430,4240)whine i have growen used to it but nothing to worry about i have used my tractors as is for the past 10 years like that.
john2510-3020
