Tie wire?
Bill Oakes
07-22-2001 13:30:27
I am putting the transmission back together in my model B. This brings me to a question: The tie wire used to keep nuts and bolts from coming loose: is this a special kind of wire or is it just soft iron wire? Also, can't help wondering if "locktite" type products have replaced the function of the wire. What do you guys use? Thanks, Bill
Bob K
07-25-2001 09:51:59
 Re: Tie wire? in reply to Bill Oakes, 07-22-2001 13:30:27
I agree with Skip and, as a pilot and Airframe & Powerplant mechanic myself, have a roll of each of the .035" and .042" stainless steel safety wire, the latter which I used just two weeks ago to safety all the bolts on the transmission of my '53 JD 50. If there's a hole in the shank or head of a bolt, I safety-wire it! I'd steer away from lock-tite as it is not as positive of a safety as wire.
Skip, what aircraft have you restored? E-mail me at [email protected]
Skip
07-22-2001 17:20:27
Bill I restore antique aircraft as well as old tractors (no wonder I`m broke). I use .035 or .042 stainless lockwire for almost everything. You can get it from Aircraft Spruce and Speciality. www.aircraftspruce.com good luck
Clooney
07-22-2001 14:16:25
Bill, I use both red loc-tite & the wire. The original J.D. wire is a little higher tensile than soft mechanics wire. You can use the regular mechanics wire but won't be able to get it as tight as you should before it breaks. I use some stainless wire that I have had for years. Make sure you install the wire so it is wrapping around or pulling the bolt or nut in the tightening direction & not the loosening direction or it won't keep the bolt or nut tight.
Kevin
07-22-2001 13:59:49
Bill use the tie wire if you were to use locktite and it came loose you would have a mess
