John Deere Model 44 plow
Dominic Centonz
07-22-2001 07:27:21
I just bought a John Deere model 44 two bottom plow at auction. Can anyone tell me when these were manufactured? Also, is it suited to be pulled by an unstyled B? What about a styled A or B? What tractor was it made for? My sincere thanks to all respondants!
Bob Collins
07-23-2001 10:45:39
 Re: John Deere Model 44 plow in reply to Dominic Centonze, 07-22-2001 07:27:21
Dominic, The John Deere #44 plow was built from 1945 thru 1957 so it was not the exactly proper or contempoary plow for an unstyled B, where it would be fine behind a later styled A or B. As to what tractor was it made for, The plow works made it to sell and didn't really care what one was pulled by, of course the dealer would try to sell one along with a new A or B of those years and, to anybody with an older model who needed a plow of that size. BTW, there are 4 versions of the 44: the 44 and 44H, both are carried (when transporting)on two wheels with the rolling landside (tail wheel) in the air, and the 44A and 44AH which transport on 3 wheels since the rear axle is mounted on bails and helps lift the plow up level. The "H" in each indicates hydraulic cylinder lift and without the "H" designation means clutch lift (pull the rope). Bob
Buckeye al
07-23-2001 14:32:58
 Re: Re: John Deere Model 44 plow in reply to Bob Collins, 07-23-2001 10:45:39
I beleive they also had two frame sizes for the 44's. The 44's had two frame sizes & they could be a 12/14 on a narrow frame or a 14/16 on the wide frame. The part that the frog bolts to had a 1" offset in them. If arranged with the offsets facing eachother (towards the middle of the plow) you could have 12" bottoms on the narrow frame or 14" bottoms on the wide frame. If you had the offsets facing away from the center of the plow you could have 14" bottoms on a narrow frame or 16" bottoms on the wide. Mine is a 14/16, set for 14" bottoms, with hydraulic lift that transports on the two front rubber tires. My mid series A's pull it very well. So does my late B. The other post gave good information & I hope I'm not out of line by adding this bit. Thanks.
Later.
Bob Collins
07-24-2001 10:59:17
 Re: Re: Re: John Deere Model 44 plow in reply to Buckeye al, 07-23-2001 14:32:58
Buckeye Al, Good info, glad you added it, you can see a guy could make a whole collection of just variations on the 44 plow and have a lot of fun using them too! Bob
Ron
07-24-2001 07:12:23
I have a 44H and I believe that they were also available in a third frame size which gave either 10 or 12 inch cuts. I'd have to check my manuals to be sure on this. (manuals are at home and I'm at work)
